Thanks for that! I'll check them out today. JeromeI have a Champion dual fuel. It's my experience that the Champion brand inverter generators have very little harmonic distortion. You'll probably need a much larger generator than I have, but Champion is definitely worth looking into. Plus, you can get warranty and parts at Tractor Supply.
will do. i'm surprised Sol-Ark doesn't have a list of recommended specs for a back up generator.@Javalord1 Please let us know if you get an inexpensive one working. I would like to get a cost effective propane one to send power to SolArk 12K to recharge the batteries.
Best case would be to support the wires for auto-start and what not but worst case I would not mind doing it manually in emergencies.
Yeah I haven't had much luck finding anything on their site. They should list clear specs and have a list of generators that have worked well in the past for others...will do. i'm surprised Sol-Ark doesn't have a list of recommended specs for a back up generator.
The requirement for 240 volts blew that $1000 limit out of the park. I've been looking for a duel fuel inverter with 240 volts for 3 weeks now and this is what I keep coming back to.... https://www.duromaxpower.com/products/xp9000ih $2600Hello from Idaho! My generator has too much hertz distortion. I'd like to find a dual fuel generator for under $1,000.
Also has to have a 240 outlet.
Many thanks, Jerome
Good call! Like I said I've been searching for a few weeks and never came across this model. Looks like if you shop around you might even get it cheaper?If you are going to spend $2,600 for a 9KW portable generator it may make more sense to spend $170 more ($2,770) for the Champion 8.5-KW Home Standby Generator which is designed to be integrated for standby use and already has an enclosure and what not...
Quite possibly. I only was aware of it because I subscribe to Engineer775's youtube channel and noticed he listed it on his website (www.PracticalPreppers.com) and did not go looking for lower prices elsewhere... Note that I have only seen him offer/install SolArks so when I saw that he also listed the Champion standby generator I made the assumption that it does work well with Sol-Arks... That means it is my assumption that they will work well together and note that anytime someone ASSUMEs something there is a chance it could make an ASS outta U & ME... ;-) It may be worth asking Engineer775 if that particular model has worked successfully for any of his SolArk 12K installs...Good call! Like I said I've been searching for a few weeks and never came across this model. Looks like if you shop around you might even get it cheaper?
Champion 100199 8.5kW Generator
The Champion 100199 is a dependable affordable generator that features a robust Milwaukee Series Commercial Champion 439cc OHV engineapelectric.com
Well what I was looking for is an inverter/gen with <5%THD so I could fool my Enphase grid-tied system into thinking they were seeing grid power and this looks like it fits the bill. The DuroMax is rated at <3% THD and the Enphase IQ7 micro inverters I have need <5%THD.Quite possibly. I only was aware of it because I subscribe to Engineer775's youtube channel and noticed he listed it on his website (www.PracticalPreppers.com) and did not go looking for lower prices elsewhere... Note that I have only seen him offer/install SolArks so when I saw that he also listed the Champion standby generator I made the assumption that it does work well with Sol-Arks... That means it is my assumption that they will work well together and note that anytime someone ASSUMEs something there is a chance it could make an ASS outta U & ME... ;-) It may be worth asking Engineer775 if that particular model has worked successfully for any of his SolArk 12K installs...
Good points. If the Duromax can be integrated to be auto-started from the SolArk it could hopefully be great for that also.Well what I was looking for is an inverter/gen with <5%THD so I could fool my Enphase grid-tied system into thinking they were seeing grid power and this looks like it fits the bill. The DuroMax is rated at <3% THD and the Enphase IQ7 micro inverters I have need <5%THD.
Having said that, the Duromax is probably more what I will need as a portable it has several 120volt outlets as well as the 30amp 240 volt plug and I can hook my 100lb. propane bottle to it. The Champion has just the main 35amp 240 volt breaker and I'm pretty sure it's set up to be permanently hooked up to propane or natural gas and won't burn gasoline.
The DuroMax can also be paralleled to double capacity to 18kw.Good points. If the Duromax can be integrated to be auto-started from the SolArk it could hopefully be great for that also.
That's the difference between an inverter/generator and a generator. An inverter/gen that puts out 120vac only is fairly common and choices are many. To get an inverter/gen that puts out 240vac seems to narrow options down to just a couple. Honda has one that I know of but it's a lot more money. For some reason the "duel fuel" requirement is where choices narrow.Still a lot to learn... It sounds like "The quite high THD (<23%) of the WGen5300DFc makes it unsuitable for powering sensitive electronic devices" according to this source:
Yeah my head is somewhat swimming trying to learn all this info...That's the difference between an inverter/generator and a generator. An inverter/gen that puts out 120vac only is fairly common and choices are many. To get an inverter/gen that puts out 240vac seems to narrow options down to just a couple. Honda has one that I know of but it's a lot more money. For some reason the "duel fuel" requirement is where choices narrow.
I looked at the lower cost option and was initially tempted to jump the DuroMax ship until I realized it's a manual start only and I'm old and broke down, plus it makes me kind of nervous to see a 50amp RV outlet on a machine that is rated at 7000 watts (just under 30amps@240) and I don't see the breaker/fuse for it. I see it's out of stock at Amazon so I'm also questioning current availability?Running a search against the www.GeneratorBible.com website for 240V, Low THD (<5%) and dual-fuel with a minimum output of 4KW Running Watts only results in 3 options (lowest cost being ~$1,500 or ~$1,200 on sale):
If I understand correctly the Sportsman GEN85KIDF can do electrical start:I looked at the lower cost option and was initially tempted to jump the DuroMax ship until I realized it's a manual start only and I'm old and broke down, plus it makes me kind of nervous to see a 50amp RV outlet on a machine that is rated at 7000 watts (just under 30amps@240) and I don't see the breaker/fuse for it. I see it's out of stock at Amazon so I'm also questioning current availability?
Uh yeah, no. You've convinced me to avoid this unit at every opportunity. This has nothing to do with starting the inverter/gen. The reviews on this are mostly horrible and I've seen enough. I always ignore 5star reviews. Usually they come from paid actors. Read the 1 star reviews, they are Legion.Edit: I re-read his review & sounds like the electrical wires to electrically start the generator came with the generator & the $70 was for a USB re-chargable battery that he used with the wires (I think you can see it in the picture above)... Note that if the battery is USB rechargeable you may be able to have a USB cable run from the control panel of the GEN85KIDF to recharge the battery when the generator is running (there is a USB port on the generator)...
You can read his full review at the bottom of the Home Depot listing:
