theoldwizard1
- Jul 17, 2020
- 77
So in the midst of one of the cold snaps in recent memory here in SE MI I am think about solar power. A few years ago, the MI Public Service commission changed from "net metering" (hopefully the correct term) where the PoCo (DTE) would "buy back" any excess power from you, AT RETAIL RATES, until you had reached a "zero" bill. Now, they only buy back at commercial rates, making your cost recovery much, MUCH longer ! Plus, they have added a large number of other "steps" to getting hooked up, some at your expense, before you can "sell" any power back to the grid.
Gone are the days of just plugging a micro-inverter directly into an outdoor 120V receptacle ! I think I have come up with a still cost effective solution, but I am sure others have done similar. I believe this type of system is called a "hybrid system".
Solar panels charge a battery bank. The battery bank feeds an inverter with an split phase 240VAC output. Output feeds the "load". With the crappy amount of sun we get here in SE MI, especially during the winter, it would be very difficult (cost and size) to have a solar array and battery bank large enough to cover all loads. What is required is a transfer switch to switch the load from battery/inverter to PoCo line power when the battery bank is "low". At the same time, the line could optionally charge the battery bank. The PoCo also got permission to can their rates for a more expensive "peak" usage, so maybe charge the battery bank off peak ? Conceptually, this is the same as a mobile "all-in-1" inverter/charger/transfer switch.
Has anyone built a system like this and how well does it work ?
