rockhardhoosier
I have 4 sunny island 6048 inverters with 4 Fla 540 amp hr batteries wired in parallel. I have a manual transfer switch . Everything had been working fine then I had to switch from solar back to the grid for a few hours. When I switched back to the solar my GFI outlets in the house tripped and anything with a motor, like my fireplace fan motor ninja airfryer/grill , my microwave water heater,all was not working correctly. But when you turn back to the grid it is fine. Well then had happened before but it was a loose neutral. Tightened it up and everything worked fine. This time there are no loose neutral grounds or anything. I even had an electrician come and double check he found nothing. He checked the hertz he checked from the neutral and the grounds to each line and we had 119-121v and when checked across both lines we had arpund 240-243v so that was good. So what could this be? The electrician is at a stand still.
