Had two MPPT 6548 solar inverters which I am replacing with a Sol-Ark 15K, while skimming through the manual it states if you are hooking up more than 2-3 batteries, they must be run through a busbar before the inverter. The SOK rack has 5 SOK batteries (no busbar) and just have them hooked up in parallel with the positive lead coming off the top battery and negative lead off the bottom battery. For those with more knowledge with these two systems, can you explain why or even IF it really is necessary with the SOK batteries.
Thank you, z
Thank you, z
