MrM1
I'm Here, But I'm Not All There
Ok, so back here I built a precharge resistor setup with push button start for my Schneider SW inverter. I used a 100w 50 ohm resistor. But it seems improperly sized as the inverter goes into a surge and blinks on and off if I hold the button more than a second or 2. The SW is trying to start but seems like it's throwing a low power fault and just kicks on and off.
I don't want to trulstartin or run the inverter through the resistor, but I feel the 50 ohm resistor is not changing the inverter caps up enough in a 1-2 second push.
So ...
I have on hand 4 differ resistors, all 100w. Which might be the best option / choice for the SW pre charge resistor?
50 ohm
10 ohms
4 ohms
0.25 ohms
@Hedges I believe you like long rolls of wire but that is not practical for my setup ?? Ideas?
Thanks
Mike
So ...
50 ohm
10 ohms
4 ohms
0.25 ohms
Thanks
Mike
