One issue with most portable, window, and mini-splits, is they lack sufficient separation between cool outlet air and indoor return air intake to cooling evaporator in unit. The more indoor immediate recirculation of cooled output air back to return air port, the worse the efficiency.
Portable units with single condenser exhaust hose to outside gets terrible efficiency. They pull the condenser cooling air from inside house and push the hot condenser output air outside from single hose. This sucks in cooled indoor air and throws it outside, and worse, it creates negative pressure in house so every window and door gap sucks in outside air to cool. It is not uncommon for their effective btu of cooling to be half the units spec's states for btu capacity..
Cheap portables also lack good thermal isolation and air cross leakage from hot condenser/compressor section to cool evaporator air flow section. Another dumb thing is placing hot compressor in air intake front section of condenser. Compressor gets its cooling from return refrigerant in suction line. Any air flow over compressor does almost nothing to cool compressor but does heat up the air going into the condenser which raises condenser temperature causing higher head pressure on compressor reducing efficiency.
There are portable units with dual hoses, a condenser input and condenser output hose. Keep the two as far apart as possible in window opening so condenser intake hose does not suck in the hot condenser exhaust hot air output.
The best portable I have seen is the Midea 14 kbtu unit which yields about 12 kbtus's which is great for a portable. It uses a dual input/output hose in a coaxial configuration with hot exhaust hose inside to the side of condenser intake air hose so it looks like a single oval shaped hose. It also prevents the hot exhaust hose from heating up the room. It is also sold as rebranded unit by Toshiba, and others that with some shopping around you can get for less money for effectively the same unit. There is a cooling only model that is a little lower cost than reverse cycle unit. The unit is also very quiet compared to other portable units.
