I purchased a house in Florida that I am renovating, currently using over 100 kWh per day, I have an old very inefficient AC unit that I will be replacing with a whole home central air mini split system, converting an old water heater to instant/on demand and I have a power hungry pool pump. The pool cannot use a variable pump because of extreme head lift and oneway valve, currently set to run 4-5 hours a day.
My goal is to reduce my energy consumption/costs and have an off-grid storm-safe system. Dipping my toes into solar, I have a plan to set up a 4kWh solar array using 400W panels on the roof and have 3-4 server rack batteries that would feed a (separate) panel and do new 220/40 runs to each appliance. I also would like to have a power transfer switch at each appliance that would be able to either run from the batter or grid.
Eventually, I would like to run a septic pump, a fridge, some emergency lighting, internet/fiber router - off this system as I scale up.
Would this type of system be feasible? Any input would be great.
