Hi All,
I'm getting ready to mount 4x 425W rigid panels to a 7x14' enclosed aluminum cargo trailer.
The details:
A.
P.S. I'm floored at the quote I received for the panels: CAD$278 (USD$218 at the moment)!
The details:
- Panels are 208.0 cm (81.9") by 103.0 cm (40.6"), 24.5 kg (54.0 lbs).
- I want to install four of them flat on the roof.
- The trailer is a 7' by 14' (Approximately 84" x 168"), with an additional 3.5' "nose" that I can use for wiring ingress, ventilation, antennas, etc.
- The roof is flat, aluminum skin over 1" aluminum square tube, 12" o.c.
- The interior of the trailer will be completely unfinished when I do this install.
- The local supplier suggested a rail system under the panels that would lift them up quite a bit. I'm looking for better ideas, anyone have suggestions?
- Any reason to mount them all transversely across the roof vs two pairs end to end?
- Since I will often be partially shaded from trees or just have inflexible parking options, should I wire them 2S2P or 4P? (These panels should run @ 40V and I have a 24V battery.)
- I have previously used simple ABS entry glands adhered to the skin of my other trailer. Is there a better option?
- All thread links, comments, suggestions, criticisms, and questions are welcome!
A.
