Pick up stuff from santan today 115°f and nasty in the oven(Phoenix)
73powerstroke
Arizona
I almost bought a sungold sp6548. But after driving 2 hrs i came to my senses.
But I did get some nice lg 250w monocrystalline panels for $51 each and a much needed 150a battery circuit breaker and a 63a dc solar breaker for some protection.
My problem is i have 20x 240w trina cracked vinyl panels from last year, 6 gloria 235w panels. I have some groups here and there and wires all over. All in 2 series. Branch adapters here and there.
A hvlv2424 inverter, several epever 40amp tracer 4210an charge controllers, and just yesterday i got my first lifepo4 battery a ampere-time (li-time) 24v 100ah battery and a older powmr 3k24v aio inverter. I usually just run one 5000btu and a 6000btu unit completely off grid and recently a 10k btu unit. Probably lacking enough solar and battery more than anything. I guess i dont know what's next for my budget solar ? but i kinda wanted something that can do batteryless operations but also not sure i want 120v only. 240v split would be nice.
Maybe i could get 2 cheap 3k aio inverters for 240.
Any hopefully tomorrow I can test out the new panels.
240v split phase, battery less and cheap don’t really go together buddy.
If you want to make everything work with what you’ve got and on the cheap then just start stringing some cheap 12v lead acid batteries with some jumper cables and only run those A/Cs during the day.
You ever seen his other threads? :p
I would never do such a thing lol ? ? ?
You were less than a mile from me. I work near Gilbert and Germann just down the road.
Yep. We came home to a storm here. Right now. Winds and lightning ? maybe youll get some tomorrow. The humidity sucks.
When did they put in the new exit behind santan off the 202? Sure makes for a easier time
That Lindsey interchange is pretty new... maybe a few months. I live to the East of there, so it's pretty damn magical for me.
We got the haboob and a little lightning in the distance. Effing June was so mild, July snuck right up on me and is kicking my ass!
Its been hot and dry even here. We broke records this weekend. My truck is now leaking oil like everywhere. Its too nasty out for me to deal with it. Not wanting to pull the turbo to see if im leaking there or not. I just paid my triple A membership and cross my fingers and pray to the diesel gods i get where i need to without being stranded on the side of the road at 115 degrees or something nutts
Not sure which truck you have but if its a 7.3 powerstroke the high pressure oil lines love going out with miles. The ones in the engine valley dead center. Starts with random oil sprays you can't tell where its coming from till it blows and leave you stranded. Been there done that :)
Yep i have two of them lol. A 97 f250hd and the 02 f350 7.3. One line was loose this winter. I tighten it and no morectrouble till now. It looks like turbo pedestal but i cant really tell.
Mines an 02 F250.
Turbo work sucks. I don't mind anything else on it but the turbo's annoying to get to.
Mines an 02 F250.
6.0L is worse.
GM isn't any different, if a turbo is needed on a Duramax, I raise the cab anymore. Ford 6.4L I raise cabs too.
6.0L is worse.
I wouldn't own a ford 6.0 and its not because they can't be reliable or anything (which they can be with the right mods). It's because at my age I couldn't deal with they way its packed in there like sardines. You can't get to anything on one of those without major grief or cab removal.
I'm pretty short so I can actually sit down under the hood of the 7.3 for working on it which helps a bunch.
I like the old dodge cummins. You can pretty much stand in the engine bay next to the six.
6.0L is worse.
Some people like them. These days the 7.3 is regarded by these new people as ancient. I guess it probably is. But it was made by for or Isuzu. And its what i could afford at the time and ive stuck with them. 6.4 has some serious problems also. Washed out regen crap and burnt pistons. My neighbor has a newer 6.7 and the turbo shaft snapped according to his mechanic. It has about 75k on it. His family has had nothing but issues with it but its a nice truck otherwise.
Im not a diesel mechanic but i might end up being one for garbage truck company.
Lately just want to sell the harley and get a honda civic or something for gas milage lol . Give me a tesla for free ill plug it in and drive it for free lol
I looked on Amazon and could decide what ones were a good choice. I should replace those anyway and then i can see if that solves it. Theres oil in places after ive cleaned and evacuated the engine valley that would indicate either spray or something
I'd replace them. I wish I had of before one blew driving down the road.
One nice thing about a 7.3 you can't run it without oil :)
Second it gets real low on oil it quits.
The things start "weeping" before they blow which could be what your experiencing and if they haven't been replaced they will have to be eventually. The flexing from all the shaking causes them to fail over time.
Oh and find out what size the flare nuts are because you will need a REALLY short wrench to take them off and put them back on. I ended up cutting a wrench in half to fit in there. So make sure you have one that will clear it all and if you don't get one or make sure you have one your willing to cut on.
I can't remember which line or anything its been years ago it happened. Seems like it was towards the front.
Since the lines can fabricated in different ways yours may not be a pain but I'd make sure before the new ones got there in advance.
I guess i can just order some up on Amazon and see how they are. One of mine on the passenger side head was loose and leaking. So i just tighten it up and was good.
Ive also got a pretty sloppy shifter at 400k. Alot of times when i back up it doesnt go unless i fiddle with the shifter.
And after something yesterday at 115°f happened where its got me wondering if its really a sloppy shifter or a tranny issue. Its alway done this since 2020 when i first got the truck. I can rebuild the trans myself but pulling it is not something i want to do in my driveway.
The truck came from Montana. For some reason the passenger side head is rusted to hell. The drivers side isnt. The cab must leak because the floor is rusted under the door jamb. Ive probably got my $6000 dollars out of it now. It had 335k on it in 2020 and now it has about 405k.
Ive been out of work a while and burned up my saving so ive just had to make do.
I spent probably 4k on solar in the last year and i made some mistakes along the way learning. Itll be a while before I see any return on investments.
My power bill is $70 this month. Was 60 last and 55 before. Apparently the window box fans all 3 raised my bill.
We run ac units with solar stuff. That saves us from a 100 to bill maybe $250 from about May to October or November. May is usually 100, then 100 for jun and 150 for July and 150 for august and 100 for September. I might save 300 to 400 a year from solar. Not great numbers for a broke guy.
The shifter play can be from two reasons normally.
Look at the end of the steering column for the shift cable coming out. There is a plate there from what I remember with two screws. They love to back out which causes it to be vague on where the shifter really is vs gear its in. It can get so bad when the screws are about to come out completely that you can't get it into park.
The second possibility is what mine has. The shifter itself where it goes into the column is just worn. Causes play. Has to be replaced which I never got around to doing :)
We still have a big bill at times with where I am solar wise but its not because it isn't saving us money as much as we waste power since its saving on the power bill.
We run the ac to much and to cold at times and when we have company it gets compounded.
The 6.0L that is Bullet Proofed with studs will run circles around the 7.3L Amazing power. Pretty reliable too. For a period, you could purchase a 6.0L on the cheap but people found out that with some mods these run a long time.
All this talk about 7.3, 6.4 and 6.0. Just get a 6.6 LML or L5P, delete it and drive it forever ?.
If I ever bought an F series it would be the 7.3. I'll never forget the time my buddy hooked his to a structural I beam that was cemented in the ground, I couldn't budge it with my little backhoe... He wrapped a logging chain around about 18" up from the ground, left about 4' of slack and hammered down... That beam snapped like a twig and flew end over end through the air, we still don't know how it didn't take out the back window or one of us ? the things you do when your young and dumb.
The time he pulled the 23"D x every bit of 20' long maple log through a frozen bank of dirt was another impressive moment for that truck.
He is a diesel mechanic and loved trying to break that truck so he could build it better.
Damned suns going down, time to go turn on overnight loads to drain my batteries down for a sunny day tomorrow.
@73powerstroke serious save up for a mini split... You will not regret it one bit. Home Depot has a few that look decent on the pro special buy of the week.
Work truck is a 2003 LB7, I pull a trailer loaded down heavy with tools, equipment and inventory. At a job today and a young 16 year old kid had his phone out and was Snapchatting his buddies about the clean Duramax I have. There was a fella hauling dirt in a dump truck and he stopped hauling to comment on my truck and how clean it was. It came from Texas, I rustproofed it when I bought it. It has been driven in winter twice, once to Milwaukee and once to Tulsa.
My play truck has the truck camper on it, 2002 LB7 that had 115K on it. Spent winters in FL and TX. It gets dirty but never has seen salt.
Over the years, I came to the realization the LB7 was superior in some ways and they will run 400K easily. I've done plenty of headgaskets and studs on the later engines such as LLY, etc. Most came in with EGR delete and still took out the headgasket. Was talking to a customer today and he had a LLY and he loved the truck until it overheated on a mountain pass out west.
The issue with deletes is coming. EPA raided every delete manufacturer and now is issuing fines to shops and end users found in the customer databases. I suspect the engines with delete may be banned from registration eventually. Currently, the EPA is comparing the database to vehicle registration records and if it is found to be registered, the EPA is issuing a fine. There might be a black market coming where a vehicle is "junked" or "reported stolen" that had a delete but the delete is actually installed on a registered vehicle.
Yes and its the last of the high pressure oil assisted injectors forget what they call it huei or something. In Arizona trucks are just stupid priced any more.
I dont care about fast or towing. I haul stuff in the bed alot but not anything heavy heavy. Firewood, 500 pound miller dialarc hf welder. Mattresses, tools, solar panels.
I dont drive my 97 f250hd extended cab long bed 7.3 4x4 . It has 4.10 gears and a zf5 and a 4inch lift. I bought it that way. Ive rebuilt the ttb front end a few times and repaced 35x12.5x18 tires too many times. The lift is weld in the front. The gearing isnt conducive to stock tire size and freeway driving. So it just sits. Bald tires . Its a ruff ride on these Arizona roads . Itll knock your teeth loose its so stiff.
