Jhp230gr45
I built mine to be movable since we live off grid only for part of the year. The 24 v system now has 8 six volt batteries unlike the picture. When I flip the switch on in the cabin it runs lights, plugs, water well and fans... Everything else runs on propane except washer / dryer that I run the generator for through the power system.. It will also run small appliances, tv, etc. for short periods.
At the end of the season I unplug the power cord from the wall where it goes into breaker box inside and the remote switch cable, roll them up, hook on the tractor and roll it into a storage cubicle and lock it up... The batteries are disconnected and trickle charged over the winter on a harbor freight solar system with dual charge controllers and are ready to go when we come back in the spring...
It works well for the most part with the exception that I'm struggling with power loss overnight from batteries even when system is not in use... Not sure if is because of my 60 amp controller on the trailer or power is slipping out through solar panels... Still trying to figure out that issue...
