Is there a document that describes the procedure for turning a solar system on & off (energizing & de-energizing)? My solar system includes two strings of 445 watt solar panels (9 panels in series, 450 volts total each, ~10 amps each), 6 EG4-LL batteries in parallel (48V, 100AH each with display), and a single EG4 6500EX-48 inverter. It seems, I first turn on the BMS of each battery then close their built-in circuit breaker (or do I do it in reverse???), then turn on the inverter, followed by closing the DC contacts of the two solar panel strings. 2nd question- Each battery has a built-in current limiting resistor and I want to know when those resistor switch-in to limit the in-rush current to the inverter, and switch-out. Thanks
