wpns
Solar Joules are catch and release
20 of those will almost match a ChargeVerter for only 4X the price. Though, as you say, meets the silent criteria.HLG-240H-54A
![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f601.png)
Oops, missed the 120v input, but same difference as they say
Oops, sorry, I meant this one:20 of those will almost match a ChargeVerter for only 4X the price. Though, as you say, meets the silent criteria.
Thanks, I think this is the derate for the 1000. Looks like not an ideal fit for 120V charging.As @Brucey says, HEP-2300-55, otherwise HEP-1000-48 for half size. I use the 2300 daily.
Both can do 120v or 240 but the 2300 derates itself to I believe 1500ish on 120. Idk what the 1000's derate is.
Side note: My 1600w rated propane generator cannot run the 2300 on 120v, it gets into a disqualifying cycle. Not sure exactly why maybe it tries to draw 2300 for a second.
Looks like it becomes a 750W charger, if that's a problem. But I don't think it hurts them to run them on the derating slope.Thanks, I think this is the derate for the 1000. Looks like not an ideal fit for 120V charging.
I have two dedicated 20A breakers/branch circuits for the washer and dryer I could switch over to 240V.Looks like it becomes a 750W charger, if that's a problem. But I don't think it hurts them to run them on the derating slope.
Are you thinking of getting one? How about the 2300W?I have two dedicated 20A breakers/branch circuits for the washer and dryer I could switch over to 240V.
I think we've lost track a bit here of what problem we're trying to solve. That would address a very specific circumstance where you only have a high amperage 120 source available like a TT-30 outlet maybe.What about using one of those 5kva Autotransformers sold by solar companies to boost the voltage before going into the charger?
Couple posts up you said one of those throttles to 750W on 120V, you can easily get 120V generators at 1500W or 3000WI think we've lost track a bit here of what problem we're trying to solve. That would address a very specific circumstance where you only have a high amperage 120 source available like a TT-30 outlet maybe.
Oh right, but you can solve that by using the 2300W version instead, which can do about 1400W on 120v.Couple posts up you said one of those throttles to 750W on 120V, you can easily get 120V generators at 1500W or 3000W
Yes seems like quite a bit of inrush when they start up. My main goal is silence, no tolerance for a screaming little fan. I'll figure out closer to winter when I may need it. Might be able to run two of the 1000W off my Honda eu2200 assuming the derate to around 700W each and startup may be acceptable, plus some redundancy there.Oh right, but you can solve that by using the 2300W version instead, which can do about 1400W on 120v.
But there's the complication my 1600W inverter generator couldn't start up the 2300W version. I didn't try turning down the output current to see if that would allow it to start up though. It's possible that would help if it's initially trying to go to full power and then throttle down to the 120v limit only after it sees the high input amperage.
Staged startup might help, let us know!Might be able to run two of the 1000W off my Honda eu2200
I will see if I can do some more testing this summer. There are several things that might fix it.I'll figure out closer to winter when I may need it.
Oh I didn't realize we can adjust the current as well as the voltage on these.I will see if I can do some more testing this summer. There are several things that might fix it.
1. Mine is a pulsar 2200W that's rated for 1600W on propane, and I was on propane.
2. I was using 125ft of 12 awg extension cord.
3. Adjusting the output current down to the intended power output, rather than relying on the automatic derating mechanism.
Yes. It has two little very sensitive adjustment pots that you turn with an eyeglass repair kit sized philips screwdriver to set the max voltage and max current.Oh I didn't realize we can adjust the current as well as the voltage on these.
