ericfx1984
- Oct 10, 2021
- 765
So I'm really trying to understand best bar sizing... I've seen a couple different ways to look at it
Some people say that you need to look at what your maximum current of all items put together could possibly add up to
Other people say you need to keep in mind which direction current is traveling
So for instance if I'm hooking four batteries together on a bus bar and each battery can deliver 200 amps... Well altogether that's 800 amps so one would think that I need a bus bar that can hand at least 800 amps
Then we take it a little further...
My loads will be for inverters at 130 amps a piece (according to manufacturer)... That's about 520 amps
In theory the batteries should never deliver more than 520 amps to the four inverters
So would I be safe then with a bus bar rated for say 600 amps since in theory I should never be pulling more than 520 amps? Or I could even pat it at something rated for 7 or 800 amps
Or would it be more important to look at the maximum current that the batteries can deliver (limited by BMS)
