I'm still working on my shed project and came across a little confusion.
EG4 provides a 125 amp breaker with the 3K inverter, and shows instructions on how to wire it. But, Will's video doesn't use it. I assume he's depending on the built-in breaker in the battery, which I also have. So, do I need the inverters breaker, or just skip it?
Wiring question for 120Vac system
I'm planning to install an EG4 3kw system in a shed, similar the portable system in Will's video. It will be 120vac. I plan to have several circuits (outlets for battery charging, LED lights, maybe a small mini-split), using a small, 8 space load center. At the moment, I need 4 separate...
diysolarforum.com
