I have a school bus conversion. I installed solar and a 12v system about 5 years ago. I recently upgraded to 1350 watts and installed a Renogy 3000W inverter charger and ran AC wiring through the bus. I've turned on the Renogy a few times before to test everything, and everything seemed fine. The plan has been to move back into our bus and leave town this coming weekend to travel out West full-time. Today was my first day working in the bus on my desktop computer.
My system:
375Ah AGM batteries (3 125Ah batteries connected in parallel)
1300W solar with 2 MPPT charge controllers
3000W Renogy inverter charger
The batteries were at 70% this morning due to a lot of rain the last few days. I plugged into shore power and turned on my desktop. No other loads were on AC power, and the DC power was only powering some LED lights, a small 12v fridge, and Starlink (no more than a 10A draw total when the fridge cycled). Everything seemed fine until around 4pm.
At 4pm, the propane detector started to beep. It has given me false alarms before, so I checked for propane leaks, decided there were none, shut it off and ordered a new one online. About an hour later, my wife came in and noticed she smelled a rotten egg smell toward the front of the bus (where the electrical system is). I was working in the back of the bus, so I hadn't noticed it. We tracked it down and realized it was coming from the battery compartment, and the compartment itself was warm to the touch.
I quickly checked the battery monitor (Victron BM700). It said the batteries were 100% full with a voltage of 14-something. But it also said it still had a net-gain of 500+ watts (it was already dark out, so this must have been coming from the Renogy). I don't understand why the Renogy was still putting in 500+ watts when the batteries were already charged to 100%. I shut everything down immediately. I opened the battery compartment and felt the batteries. They were warm to the touch, borderline hot. The rotten egg smell was much stronger when I opened the compartment. After 20 minutes or so, I had grabbed my laser thermometer and checked the battery temps. They were at around 130 degrees Fahrenheit.
Now I have the batteries completely disconnected and sitting outside.
I'm wondering what to do from here. I don't know why the Renogy over-charged the batteries. I want to confirm that I had it on the correct setting (I'm 99% sure I did), but I'm going to let the batteries cool down overnight before connecting the Renogy to one of them to power it up and check the setting.
Questions:
My system:
Questions:
- Are my batteries toast? (I assume they are)
- Is my Renogy going to do that again?
- What should I do going forward? I'm assuming I need new batteries and possibly a new inverter charger. I want one that is reliable and safe and not going to burn our bus down with us in it.
- What batteries and inverter charger do I get?
- Where can I get them so I can have them as soon as possible? (again, we were planning to move into the bus full-time in 4 days)
