I put a new 12v 200ah Litime battery on a renogy charge controller into a van build. I initially configured the renogy with the following settings:
High Voltage Disconnect: 14.2 V
Charge Limit Voltage: 14.1 V
Equalize Charge Volt: 14 V
Boost Charge Volt: 14V
Float Charge Volt: 13.6 V
Low Voltage Alarm: 12.1 V
Over Discharge Volt: 11.1V
Discharge Limit Volt: 10.6 V
TODAY: The voltage on the controller was set to boost with v= 14, but the victron monitor read 13.2, so the battery was not charging and was also only half charged. I rebooted the system. It started acting weird. I took a video of the problem today (FF to 16s):
I believe the error message that displayed was E1, battery over-discharged, and maybe i even saw E2 show up, battery under voltage.
with USER profile programmed settings, the batteries voltage increases quickly once pv is connected, and then the system shuts down. The "true" battery voltage right before the PV system was turned on was about 13.2.
UPDATED SETTINGS:
I changed the settings from USER to LI today, the Renogy native profile. I haven't monitored this new profile too closely, but issue hasn't reoccurred yet, possibly because the charged voltage on the LI profile is higher, at 14.4. When the battery voltage approaches the charged voltage at 14.4 will the same shut down will re-occur?
I didn't charge the battery to full before installing in the van. Was that necessary? Thanks for your help in letting me know what happened and how to fix.
UPDATED SETTINGS:
