I think it was putting out 65 watts when I first started.40W output thermoelectric generator? How much does THAT cost? Got a link for replacement part?
Could be up to 1kWh/day for people burning wood, oil, whatever.
You are correct, this is a super temporary setup for the proof of concept and to test the shunt and DC to DC charger, the final version will be LiFePO.I think I see a shunt but not a fuse, suggest adding a battery fuse.
Two batteries in parallel, charge controller connects with both wires to one battery. Having charge controller wires go to positive of one, negative of the other provide better balance of current (only matters at high charge/drain rate.)
FLA batteries release corrosive gasses. Suggest you enclose/vent outside in some way so electronics doesn't get exposed to that acid.
Link posted above.@yancy Do you have link to the thermoelectric generator?
Ok.. I think I'm a bit confused Does that SHC35 heater have the thermoelectric generator included with it? If so I was mistakingly thinking you had purchased it separately.Link posted above.
sorry, I cannot find the link. can you help me, please?Link posted above.
Click on the space heater link above.
