I’m using a Renogy 30 amp DC-DC/MPPT charge controller to charge my SOK 206 AH Lifepo4. The “lithium” setting on the controller bulk charges fine, but when it hits the boost setting it seems to hold the battery at 14.6v indefinitely, and stay in “boost”. The charging amps drop to zero/near zero, but the battery doesn’t ever drop down to the usual 13.8ish resting or voltage. Is this a problem? It doesn’t seem that the controller is trying to cram more voltage into the battery, but I’m not used to seeing my battery sit at 14.6v all day either (coming from AGM batteries so still learning about lifepo4 charging) This happens when my camper is sitting outside in the sun while not being used. When I apply a load to the battery it rapidly drops to 13.7v or so and the charger returns to a bulk charging mode until it hits 14.6v again. Am I damaging my battery by letting it sit at 14.6v for an extended period of time? I can pull the fuse on the solar and stop the charging (which returns the battery to a normal resting voltage of 13.8v), but I don’t want to have to mess with this every time I let my camper sit idle in the sun for a few days.
I have tried to input the manufacturer recommended SOK charge profile as a “user” defined profile with similar results. The SOK profile calls for a 15 minute boost at 14.6v and then a float charge of 13.8v. I know lithiums don’t really require a float charge but that is what SOK reccomends. Even with these settings the charger stays in “boost” and holds the battery at whatever I have the boost voltage set to.
After researching it seems that Renogy recommends their lithium batteries be charged to and held at 14.6v.
The TLDR is that I’m looking for recommendations that won’t damage my battery but also won’t require me to manually adjust the boost voltage every cycle to fit SOK’s charge profile.
Thanks for any advice!
I have attached my settings below:
