Sh*t, I've kinked my line set while trying to install my mini split to cool down the inverters (sorry it's a bit off-topic, but related...).
Some help appreciated:
My house builder pre-wired the RV garage for 2 mini splits - everything is running nice inside the wall. Beside the existing electrical wiring and disconnect box, he also installed a 3 inch pipe for the line set and a small 1 inch pipe for the condensate drain line to connect. Now I have a real hard time time to push/pull the line set through the 3 inch pipe. The 3 inch pipe on the outside wall has a small angle (about 20-30°) where it comes out of the wall.
My problem is to push the (16ft) line set (together with the attached power cord and curled nicely with the non-Adhesive wrap which comes with the line set) from the outside up through the pipe. I've tried it a couple of times and it always stuck just about 1-2 feet before it would slide out on the inside wall unit (I think it will stuck where two pieces of the pipe are connected and the connector screw of the line set will hit against the inner pipe edge where the pipes are connected). Also I've tried to use conduit wire pulling lubricant, but no success. I've tried it also one time to push it down from the upper inside end, but it's horrible to stand on the ladder and handling the line set, also there is not enough space between the ceiling and the beginning of the pipe - this was the situation where I've kinked the line set.
I think I need to do it while pushing from the outside upwards is the correct procedure. Now I hope someone have an idea how pros are installing line sets in such a situation. I think about putting a sort of a rounded smooth hard plastic cap (e.g. from a small hard plastic bottle) over the line set connectors to make it easier to slide over the inside pipe edges.
In the attached picture I've marked the location of the 3 inch pipe with red and the 1 inch condensate drain pipe in blue color.
View attachment 152701 View attachment 152702
Any ideas?
Thanks in advance.
