OK, try this on for size -
@Rednecktek pls check this
I attached the drawio file and picture in a zip if you want to download and modify (either of you)
I changed some of the links to be more appropriate wire and I added a main disconnect switch and an active equalizer to keep the batteries in sync.
Don't skimp on the switch - I picked one of a brand I know is good, this is one place the cheap knock-offs are pleantiful and not nearly so good. You can get a cheaper version, just make sure you know what you are getting. If you pay less than $15 it is very likely junk.
Also changed the breaker to 16amp dual pole since it was talked about being for disconnecting the PV wires verse being inline with the inverter.
I don't have one of the battery monitors you linked so I have no idea what size the shunt bolts are.
@platinumphoenix - You will need to figure out what the correct lug sizes are when you order cables - they have to be right.
I linked the windy nation pre-made battery wires on Amazon - they are good stuff and you can't go wrong.
Note - I may have missed a link from prior posts - so ask if you have questions
Noticed I listed the wire between the batteries as 2 AWG, it should be 4 AWG.
And I just noticed that the 10awg wire from negative of MPPT should be going to the other side of the shunt
Fixed now
Did I miss anything?
You have batteries - 12v 200ah - connected in series to get 24v
Equalizer - connects to the batteries to keep them in balance - required
Wire between batteries and to hookup to inverter and breaker are 4 AWG - pure copper with lugs - these are the 2ft version
Need to know what size the screws on your batteries are and bolts on the shunt
Wire between the solar panels and the MPPT and splitter
MPPT - Charge controller - bougerv 40amp
Battery Monitor -
@Rednecktek - what size are the bolts on the shunt? 3/8 or 5/16?
https://www.amazon.com/gp/product/B07FGFFHC6
Fuse, holder, cap
https://www.mouser.com/ProductDetail/Bussmann-Eaton/MRBF-150?qs=r5DSvlrkXmKYtJ1cVnWOqw==
https://www.mouser.com/ProductDetail/Bussmann-Eaton/CFBAR1-250SP?qs=r5DSvlrkXmKMfmwp3Zb/Bw==
https://www.mouser.com/ProductDetail/Bussmann-Eaton/CFCOVER-1R?qs=zijbFIqa2JEOjMDsOT7upA==
Ground wire
Ground rod
Breaker - changed to 2-pole (if you are using to disconnect solar panels you have to do both poles - NOTE the breaker is polarized - so have to get the pos and neg in the right place.
Battery disconnect - this is your on/off switch - 3/8" screws/lugs
