I live in San Antonio where the high so far this year (that ive noticed from checking my phone, not official by any means) is 108F and heat index 111F. I’m living off grid with no grid connection whatsoever in a ~900sqft structure with very unimpressive insulation and ZERO shade on the structure after about 8am. I can tell you that i am using about 3kw running window units to keep this structure comfortable in these conditions during the heat of the day, roughly 10-6. From 6-10pm i am compromising my comfort desires a bit and curbing my ac ‘consumption’ down to 1000-1500w which doesnt keep the whole house cool. From 10pm to 8am i run only one 8000btu midea inverter window unit in a bedroom which averages <250w on lowest settings set to 73f in a ~160sqft room, and that time is covered by batteries.
So my ac power draw ranges from 250w for 160sqft overnight to 3000w for 900sqft during the day.
I also have a 20x25 metal building with firberglass insulation (not sure R value), and a 12x12 uninsulated poorly sealed roll up door. I can keep that cool with 2000w during the day.
In my opinion, if you insulate a 25x25 well and buy an efficient mini split, you can probably cool it with 1000w or less continuous during the hottest part of the day, and at night your power draw for cooling should be no real issue even with smallish battery. I would encourage you to go 240 on the mini split because it’s more efficient and the wiring is cheaper. All my numbers would be better with mini splits but the fact that everything already ‘works’ on free power and paid-for batteries is undercutting my motivation to improve. ?
Im sure someone would rather i express all this in kwh but i rarely look at it. I put a power meter on the old 5000btu window unit i used to have in my room before i went off grid, and once i found out it was using <2 kwh overnight, i said ‘oh, no big deal then because i can easily cover that with batteries, my next ac unit will be more efficient, and my 10kw array will cover everything during the day’ and stopped really tracking any kwh and since then im just ‘spot checking’ the wattage on my inverter screens.
