Perfect. Thank you so much for your help.
I have another one issue or just a question.
I got my 16 x 280ah cells 3 weeks ago perfect match from BASEN.
Yesterday I started building my battery pack. First I put them in parallel and try to charge it with my 5 amp bench charger.
The cells was at 3.295v at this time. I wait 2hours and nothing happened on the voltage how I guessed before.
Than I put all in series to build a 48v battery and wanted to charge them up so far I can.
(Because Will says in his top balancing video. After that back in parallel and charge them up to 3.6v)
So I build the 48v pack and put the BMS 48v overkill on it. But I made maybe a mistake. I put the first negative on the main negative than on all next positiv pole till the last Red Wire to main positive. Check all voltages on the cable. It was all good. 3.29, 6.40, and so on.
After that I connect the white and the black cable bank on the BMS.
I have a look on them and 3 or 4 cells showing me with roughly -0.07v means completely empty.
I took them all out right away.
I connect all wires new! Exactly like the manual from overkill.
Connect them again without the blue cable and the red load cable to the batterie. Now 2 or 3 cells was not correct showing me.
I connect my charger and all cable and it does work. Showing me all cells as the correct voltage.
So than I charge the battery up to 17h. 7h with 10amps and 10h with 18-22amps.
I set all the settings standard, 280ah nominal and 224ah cycle, the BMS was not show me any errors or other issues, all normal. But....
Now here my concerns:
So I load the battery, the capacity shows me at the first time 134ah with 3.29v, than I reset the capacity one time, than shows me 250ah in the battery. I thought 134ah it's a way to less for fresh delivered cells.
I started the charging. After couple hours was 280ah reached. But charging further, I reset the capacity again. Than shows me 170ah. Reset again, shows me 260ah. I charged them further. I did that maybe 6 times again and it jump everytime back on 260ah.
Know I had 272ah and doesn't jump back a anymore. Two cells reached 3.65v now. The rest still on 3.390 roughly. Put them back in parallel and load them full to 3.60v further.
Now my questions, is this all normal what happened? how you can see attached the pictures, all the time the cells are in yellow range and the half of the display like 50%. Just shortly before that 2 cells reached 3.5v the colour changed to green. But not the whole box. I saw many videos, on all that videos the colour was green.
Please ha e a look on the pictures.
Did I killed my BMS in some way? Or a wrong setting or what can be the reason for that?
Very appreciate that when you guys have some answers for me.
Thank you a lot in advance.
