Zeebest001
For the two T's and 2 hoses, I should use the same metal as everything else correct? I don't want to mix and match plastic with metal etc.
So I should look for some Brass T's
They make check values. Generally, sump pumps use a check value to make sure the water won't drain back into the sump. Just get a decent one with a solid check value design. The cheap ones have little rubber flaps that won't be adequate.Before I replaced my booster pump, I believe I had a well pump. For some reason the water would still run through the well pump even without power, I just wouldn't have great water pressure, but I could still flush toilets and the water pressure wasn't that bad. Ideally I would like to have a setup like this, but I have no idea how to achieve it. The well pump wasn't ideal either because it would turn on when the pressure got low and build the pressure back up, then turn on when low and then build the pressure backup. The booster pumps keeps the water flow constant. Is there a way to make the booster pump have water run through it but not get the "boost" when I lose power? That would be ideal.
yea he already has a drawing for it
Running booster pump 24/7 Questions before I make an order
So the thing I circled is the check valve and I just need to simply replace that with a lower PSI one and my problem will be solved? If I am understanding correctly? maybe.. depends if your pump lets water through or not You can just remove it entirely and check if water creeps through...diysolarforum.com
putting a check valve there will make it so he doesn't have to do it manually
only costs extra $30
I would say I get about 20% flow rate maybe even 25% flow rate without power, adding the booster gave me 100% flow rate. After adding the booster during a power outage I would get no water, so thanks to this form, I now know what I need to order to bypass this during a power outage.
Having gravity pressure is fine with me, it was enough pressure to flush the toilets, and do basic things, such as the shower would work at 25% vs 100% flow. I am fine with that.
I can't live without any water as I will have airbnb guests at my place. So I just need a system that will allow water to flow from the cistern to my apartment during power outages, they can last from a few minutes to a day.
wow prices are all over the place,
Gotcha!
I will do this and be done with it!
All you need is 2 tees, 2 hoses, that grainger check valve above
should be like $60 total or whatever
thanks again! Saved me a lot of money trying to buy an inverter and battery and this will be a much better solution!
usually yea, but you have PVC + filter up above the tank so you already got a mixFor the two T's and 2 hoses, I should use the same metal as everything else correct? I don't want to mix and match plastic with metal etc.
watch out for these, no cracking pressure psi rating. I'd just get the one I already linked at 0.5psiThey make check values. Generally, sump pumps use a check value to make sure the water won't drain back into the sump. Just get a decent one with a solid check value design. The cheap ones have little rubber flaps that won't be adequate.
Loading…
www.lowes.com
look up what a cistern is, it isn't even pressurized from the pics I see. It's literally an open tank lolShower?
The line from street must be applying some pressure to the cistern tank.
his pump before probably was easier to turn and it probably had no check valve on itSorry I was late to the party. So you had no pump before and it worked ok but performance was just low. 7 feet equals about 3 PSI at the bottom of the tank.
Fly me out there and feed me and I'll hook it up directly to that line feeding the cistern and put an accumulator tank so it keeps pressure lmaoI don't think it is, the city line has to go up to my third story apartment. There the water fills up my cistern and has a ball valve, it shuts off when the cistern is topped off. So all the city water is doing is filling my cistern. I think it is the downward pressure from the cistern that is giving me water pressure during a power outage.
Shower head is at 60" height. If tank is 7, that's like 1 PSI he's showering at.look up what a cistern is, it isn't even pressurized from the pics I see. It's literally an open tank lol
generally I'd say yea hook directly up to the water line.. and use an accumulator tank to keep it pressured
Loading…
www.lowes.com
He's gonna get like nothing out of the shower, as far as he said he just wants to be able to flush toilets and such when power is out lolShower head is at 60" height. If tank is 7, that's like 1 PSI he's showering at.
I guess that would work? Sheesh though.
OP, do you give discounts to customers who can't wash the soap out of their butt crack?
he had a tank? as far as I saw the pump just ran when you opened a tap / shower and shut off when it wasn'tPerhaps. That would be really counter-productive to have a pressure tank and no check valve.
LOL hey man that trickle of water is pretty good for a lot of countries. Many places you're still using a bucket of water and a sponge outsideOP, do you give discounts to customers who can't wash the soap out of their butt crack?
must be some check valveI'm just curious how the shower worked with only 2 feet of head pressure. If the cistern is open, what keeps it from overfilling if he forgets to shut the city inlet off?
