I am considering doing a "drop in" conversion with the Chins battery. The question I am hoping someone can answer is "What happens when the battery runs out?"I do still have the stock monitor hooked up...it doesn't really serve a purpose though, as it's not accurate, and the Vatrer came with its own that plugs right into a RS486 port on the battery.
As for the runtime, I haven't tested it thoroughly, but so far it's looking like I got a little more than the Ryobi had even in it's first season.
I got 3 acres to mow, and on the stock batteries in the first season, I'd end with 10-20% (which I reduced doing as it's bad for the batteries), this new one has ended with 20-30%
Of course the stock batteries going from season 2-3 started going under 20% before half the yard was done.
With the stock AGM and the stock monitoring systems, it will stop the blades but the mower will still drive, allowing you to return to the charger.
With a conversion, will this thing just die?
Thanks for any input?
