MisterSandals
Participation Medalist
I have been messing with this for a few weeks and am stumped about the "AC Couple Smart Charge" feature. It works as written in that it will take AC micro inverter power and charge batteries first and then pass thru the rest to the grid. I turn this feature on with the "AC Coupling" control enabled.
The problem that I am having is figuring out how to USE the battery without inadvertently disabling the "AC Couple Smart Charge" feature.
I see 2 ways to configure to use the battery power:
1) "AC Support Mode Enable" enabled
Uses battery power to "support" my critical loads panel by some unknown amount/metric as long as battery voltage is above the "AC Support Voltage" (set to 52V).
Enabling this disables the AC Couple Smart Charge feature (meaning it stops charging the batteries from my micro inverters/critial loads panel).
2) "Peak Load Shaving Enable" enabled
Uses battery power to "support" my critical loads panel (above set number of AC amps, 1A, the minimum value, in my case) as long as battery voltage is above the "AC Support Voltage" (set to 52V).
Enabling this also disables the AC Couple Smart Charge feature (meaning it stops charging the batteries from my micro inverters/critial loads panel). I can turn off Peak Load Shave with the start and stop settings for the period I expect my micro inverters to be producing an excess over the critical loads panel use. I can set it for 11AM stop when my array is currently in full sun and to start at 4PM when the sun currently goes behind trees. This "currently" works but would need to be adjusted continually to maximize excess power. Controlling this "smart" feature manually in such a way seems wrong and inconvenient.
I spent the last couple weeks trying different features and different combinations without any success in finding a good solution. I know i could use node-red to toggle either of these features as excess power is sensed. Why would a "smart" feature to charge batteries prohibit using the batteries without intervention?
There is a control "Charger Override Enable/Disable" that appears to have no affect on any of these settings.
I am attaching screenshots of my settings as well as a .json file (human friendly in a browser). If i am missing anything, please ask.
Thanks for looking!
Thanks for looking!
