400bird
Solar Wizard
That's not quite what I had intended. You'd use one normal relay and one timer relay to open the cool request line for B (if B isn't already running) while A starts. That way, B can't start while A in starting. Edit: use a timer relay here so that B will only be blocked out for something like 20-60 seconds, or whatever your testing determines is needed)was thinking..how would this fix it? If both turn on at the same time, the relay would put some random delay on both circuits, which would work. But there is a chance that if they turn on at different times, then the timer relay would sync them to start at same time..
unit 1 : t0 + 5 sec = t2
unit 2: t1 + 7 sec = t2
am I off?
You need a standard relay to open the command from A to the relay if B is already running. Otherwise, every time AC unit A started, it would cut out B for 20 seconds or whatever your timer is set to.
