Not sure, I downloaded it directly from Schnieder, under the Technical publications for the insight home device. it's a zipfile of modbus maps for the whole ecosystem.
As for your node-red setup.. You'll want to use the mobus-flex-getter, since you are trying to get a value, not write a new value.
This is what I ended up with:
quantity is 1, since it's a uint16, not a uint32 (I mention this in my writeup)
I also mention, if you are writing a unint16, you don't need to do all of the buffer manipulation, and inclduded a function code example to show a 16bit write
