You can manually change the SOC, normally when I set these up for a customer, I top balance all the cells to3.65, hook up a new Seplos unit, login with admin & admin, go to upload settings, change the battery capacity,rated capacity, then change the SOC ah to whatever the cells are rated for, the change the top end cut off and bottom end cutoff, enable the balance and minimum delta then its job done. you have a fully charged pack, set at 100% soc noted with zero charge cycles ready to go. Section 58 & 59 are what you want to change.
