Seplos CAN BUS RS485 48v 200A 8S-16S BMS
I have found if you have any DIP switches in the "ON" position, it won't connect to the app. Check that the BMS you are connecting to has them all turned off.
I did a full discharge yesterday. Capacity reset to 226Ah but this SOC number stayed at 100
Ah my bad, sorry didn't read it properly. I wouldn't manually reset an SOC personally. Unless I had some other means of measuring capacity like a smart shunt or similar.
I was just wondering what that setting does as it says 100Ah and it hasn't changed.
To my understanding, SOC is supposed to be the current State of Charge at that point in time. So if you know the battery is at 50%, but its reading 60%, then you can manually select 115ah to tell it.
I think the default value is 100ah, and does not update to reflect the actual SOC.
Just my thought. Idk if its true.
Thanks. I'll just leave it at 100Ah because SOC seems to be accurate
Is it OK to have the cell and total voltage alarm at 3.5V and 56V the same as the protection? Or should the alarm be slightly lower than the protection?
Also can I leave recovery voltages default or should they also be lowered?
alarm should be below
alarm triggers a 10 amp charge throttle so your bms has a chance to balance your cells
Has anyone experienced this? My SOC was showing around 70% and was getting a good charge, no big loads. When all of a sudden my SOC drops to less than one percent and starts beeping with a "Remaining Capacity Protection Alarm"? Even though voltages all show it isn't at 1%?
Also does anyone know how to stop the beeping? ? I've contacted Seplos but as it is Saturday evening right now I don't expect a response until Monday.
I had a similar event and found a bad (intermittent) connection on one of the bms sense wires.
I got lucky and happened to see the cell showing low voltage and upon wiggling the wire, found the bad connection. The sense wire had been extended to reach the terminal and I had done a poor soldering job.
Kid
Kid
On a Seplos system?
My Cerbo showed an imbalance error too.
Yes Seplos, I have the can model that this thread originally pertained to.
Kid
Ah ok, thanks for clarifying. I was extra careful while connecting them, and it's been running for a month with no issues so far?
It seems to now be fine and charging again without any manual intervention, albeit from an incorrect SOC?
I'm not sure what has happened. I think something has failed and it has cascaded.
I have a typical Victron setup with a Lynx Shunt with two Lynx distributors either side, a Multiplus and 2 x Victron MPPT charge controllers. My Lynx Shunt now seems to be dead with no lights and not recognized by my Cerbo, yet my battery is still being charged by my one remaining working charge controller, and I have one charge controller showing an "Solar charger Error code 87 - PV input shutdown" error?
Is there a way to manually set the SOC via Battery Monitor 2.19? It's reporting 17.7% SOC with a battery voltage of 53.98. Or will it manually reset to 100% if i'm lucky enough to get enough sun with the remaining charge controller for it to automatically detect it's at 100%? Although at this point I really don't know what to believe.
Apologies for post bombing, I'm just not sure what to do for the best and really don't want to switch back over to the grid after a month off it.
