Hi - I have a 10E BMS connected to a Victron Multiplus 2 with a RP and CAN hat used for load shifting so no other DC charging. With the BMS CAN disconnected the battery can charge at 70 Amps as expected but when CAN is connected the charge current is limited to 47.5 Amps. This limit is shown on the RP display in the BMS parameters.
My question is how can I either adjust or remove this limit? I can't find any settings for it on the RP display or in the Seplos PC software.
How to Set Charge Current Limit - CCL
After hours of searching Carl at Seplos Got me sorted.
I can't remember where I got this from (probably in the manual) but it explains how Seplos set up the CCL -
Charge Algorithm for the Seplos System:
1: Charging current limiting algorithm
1.1. A device triggers a charging alarm of voltage, temperature, current and capacity or any charging protection, and is judged as no charging current;
1.2. When zero devices can be charged, the charging current is fixed at 10.0A;;
1.3.
When a single device can be charged, the charging current shall be ["Charging Overcurrent Alarm Value"-10.0A]; If the charging overcurrent alarm value is greater than 20.0A, it will be reduced by 10.0A, and it will be fixed by 10.0A when it is less than 20.0A;
1.4. When more than two sets can be charged, the charging current shall be ["Charging Overcurrent Alarm Value" * number of sets/2];
1.5. When the voltage of any single cell in all parallel battery packs exceeds "set value of monomer overvoltage protection" +30mV, clear the charging current and set the charging capacity to 0A;
2: Discharge current limiting algorithm
2.1. A device triggers the voltage, temperature, current, capacity discharge alarm or any discharge protection, and is judged as no discharge current;
2.2. When zero devices can discharge, the discharge current is fixed at 0.0A;;
2.3. When a single device can discharge, the discharge current shall be ["Discharge Overcurrent Alarm Value"-10.0A]; If the over-current alarm value is greater than 20.0A, it will be reduced by 10.0A; if it is less than 20.0 A, it will be fixed at 10.0A
2.4; if more than two units can discharge, the discharge current will be as per "Discharge over-current alarm value" * number of units/2;
The one bit I was missing, that I got from Carl, was that the last (at least on my setup) function switch "
Single BMS 1.0C charging" needs to be set to "
ON" otherwise as 1.4 shows it will set the CCL to half the "Charging overcurrent warning" setting, 95/2 = 47.5 in my case.
Now my CCL is at 85 Amps (Charging overcurrent warning - 10) well above the 70A the Multiplus can put out.
Carl also said to check the top 5 or 6 function switches but they made no difference for me. Not sure if they should be on or off so I left them as they came and what seems correct - all on.
