Hello all,
i didnt plan it out very well and found out that i forgot one more bus bar for the negative wire for 40a SCC + battery + inverter, but then i have a 50a breaker laying around, can i use that instead of a bus bar? so battery will be on one side while the SCC and inverters to be one the other side of the breaker.
for the inverter, i don't plan to go over 50a load, but i do have a 60a fuse on the positive side from battery to the inverter already. not sure if that makes any difference.
thanks again for all of you guys' helps so far. super appreciate it.
