Shutdown Daly BMS with Switch on balancing input
denmek
Hello guys,
my challenge: I would like to remotelly deactivate BMS in my caravan. The termination of power cable is not the preferred solution, therefore I am looking for a logical one. Thus the idea on balance cable came to my mind. Did some one treid out to terminate one of the B1-4 or GND line in the 5 Pin of 4S BMS cable ?
I know Daly is quite picky on this cable therefore need some advice if there are some no-gos . Logically in case B1-4 can be disconnected the BMS should shutdown due to low voltage issue on the sense line.
hope the case is clear and there is some experience on that
thx, Daniel
If you're proposing triggering a BMS shutdown by "cutting" one of the BMS sense wires so that a single cell reads 0V, I think it's worth a try. You can clearly conduct the experiment yourself by simply disconnecting one of the sense leads and seeing if the desired result is obtained.
