Bad News... after all that (above) I have failed completely to get my EG4 -
24v battery to start my
2,000w 24v inverter.
I've tried using a parallel pre-charge circuit, with various sized resistors and a momentary switch, from battery to "+" In on the inverter. Sometimes it works... most of the time it fails. I've tried WITH the rest of the "house" circuit connected... and WITHOUT... both failed. I've tried with the inverters own, on-the-box, switch turned on and turned off... both failed. I've tried directly connecting the EG4 to the inverter and turning on the master EG4 switch... sometimes yes, mostly no. SS's only solution was to buy their 48v AC breaker... supposedly because it can "snap" quickly and prevent the arcing they think is causing my problem. I tried the breaker method... using the much faster DC version of the breaker... failed. In every case my BMS software throws a "Short Circuit" error message and instantly shuts down the system.
In all cases there is NO LOAD on the inverter... other than the pre-charge capacitors of course.
Oddly, sometimes the system resets after about 1 minute all on it's own and sometimes I have to manually reset the master breaker. What is happening that is different... I can't figure it out.
Has ANYONE been able to solve this problem? How can a battery this nice NOT be able to start up a tiny 2,000w inverter with NO load????
@RichardfromEG4 I've PM'd you about this problem... no reply... still out there?
