Troubleshooter
Does Sol-ark publish a changelog on what has changed from version to version?
No they don't. I asked the tech about it again and he said they should soon be adding one to their website.Does Sol-ark publish a changelog on what has changed from version to version?
Cool, I'll check this out.FYI - Interesting Github submission related to controlling DEYE/Sunsynk inverters (which should also work for Sol-Ark) via HA
https://github.com/kellerza/sunsynk
Planning on playing around with it over the next few weeks. NOTE - the modbus registers are different when it comes to the phases, see 1st post, so we'll need to tweak them if there are calls to them. Use at your own risk.
BTW - here is the original post that got me started last year on this path, still active with some great info. https://powerforum.co.za/topic/8451-sunsynk-inverter-monitoring/
I love that design the best. It's just so simple and yet gives you all the info at one glance.
Success! Im pretty sure this is what fixed it a couple of days ago. I turned off the invertor and the PV and battery breakers, let it sit for about 20 mins. Then turned every thing back on. I didnt think it worked at first because I was using CERRXIAN RS485 to Ethernet RJ45 TCP / IP Serial Device Server Converter and the invertor was still not responding. On a whim this morning I reattached what I originally purchased DSD TECH SH-U11F Isolated USB to RS485 RS422 Converter via USB and got data flowing!bounce = reset/restart or maybe restart the whole inverter
would be easier to hard wire and port mirror via switch to capture the data, probably will be encrypted unless this esp can do man in the middle, also dongle only sends data every 5 mins which is the big reason everyone is trying to use rs485 to get to 5-10sec intervals on data visibilityHas anyone looked at the Sol-Ark dongle WiFi to an ESP8266 access point programmed like this to monitor the packets and then interpret the captures to get the data you want while relaying the original data on to it's destination? Basically a splitter in software. Or is the update frequency too low to be satisfactory. (I won't be installing my 12K for another month or so - I'm only beginning to study the issues here.)
Are you talking HTTPS encryption, or just that the dongle is encrypting or compressing the messages?would be easier to hard wire and port mirror via switch to capture the data, probably will be encrypted unless this esp can do man in the middle,
why is this preferable to just working off the modbus jack?what would be cool is to figure out and copy flash from the existing dongle which is an ESP (pretty sure there is away) , edit code to enable network modbus tcp option that deye and sunsynk inverters have and reupload to the dongle and all problems are solved
Hi, we are trying to make this connection but I haven't had any response from the inverter. Can you tell me more about the connection you've made? so I can try itNot sure if the device supports Modbus over TCP natively. The WiFi dongle connects to a 9-pin RS232 port and communicates using a standard serial protocol.
I tried to get the RS485 working but could never get any talk-back from the inverter. RS232 over the 9 pin serial works just fine. I have no interest in using their stupid app, so I wasn't losing anything getting rid of the WiFi dongle.
I purchased an RS232 to Modbus TCP converter (USR-IoT D301 from Amazon) and use that to read the registers using a Modbus plugin for Home Assistant. I imagine one could do the same with NodeRed - Would be cheaper than setting up an RPi to do the job.
I got specialty cable shipped free at AutomationDirect-That free kicks in at 49$-no cut chargers and fast shipping-My cable was Quabbin Data cable 3 twisted pairs -160 feet for Tigo Tab to CCA unit from array to an outbuiling with web service to the cloudIs there a source for the RS485 cable where I wouldn't have to pay $55 for shipping?
Hey, sorry I did not see this response before.Hi, we are trying to make this connection but I haven't had any response from the inverter. Can you tell me more about the connection you've made? so I can try it
You have to connect to each inverter. However, a recent firmware change to the Sol-Arks now follow the modbus index for each unit. Before, each unit responded to address 1 (for both master and slave), Now, master is 1 and slave is 2, but each still has its own serial connection to your host computer. Took a little bit of testing to figure out what was going on when my python script stopped working!I have two Sol-Ark 12ks in Parallel. Do I need to have both connected over rs485 or can I just connect to the master?
I'll have 4 280ah 48v batteries with their own JKBMS connected via bluetooth to a raspberry pi and hopefully talk to the inverters over CAN to tell them how much voltage/amperage to charge with and report on battery data. It would be great if I could do it all with just one Pi 3.
What Software did you use on the PI to talk to the JKBMS via BT?I have two Sol-Ark 12ks in Parallel. Do I need to have both connected over rs485 or can I just connect to the master?
Well I currently have my Batrium/Sol-Ark operating smoothly and looking to the next stage of monitoring. So I began reviewing this thread that you had posted. I have a raspberry pi 4 and a Lenovo laptop. My laptop currently has the Batrium toolkit downloaded and that is what I’m using to monitor Batrium. However I want to use my raspberry pi to monitor my Sol-Ark just as you have stated in this thread. My first question would be, do you have your Batrium toolkit download on the raspberry pie? I was looking into that and it appears Batrium needs a Windows based operating system for the tool kit to work.In short real-time monitoring is possible with the Sol-Ark!
I decided to post a dedicated thread on this topic given the ongoing interest and research that has been done by some members. I am pointing folks to the resources that I used for the primary setup but will highlight the Sol-Ark specific items that I discovered on my own that made everything work.
Background Info - I have been on the 'search' for a way to monitor my Sol-Ark 12k inverter since I bought it. I was unimpressed with the out of the box offering and discouraged with every firmware release that pushed monitoring frequency from 5min to 8mins and now 10mins per reading (today I am monitoring at 1 sec intervals). I had some limited experience with logging and graphing with my Batrium setup so I started looking and came across this site where the members had successfully accessed the SunSynk inverter, 'cousin' to the Sol-Ark. A cousin to the point that all the modbus registers are the same outside of the ones related to the grid phase side, SunSynk is single phase vs. Sol-Ark being two phased. See attachments.
Setup - I followed the steps that have been outlined in the following two posts (posting them for credit). Read these threads and read then again and you will be 90% of the way there setting up.
https://powerforum.co.za/topic/6875-software-for-sunsynk-pylontech-combo/
For my setup I used the following items:
Sol-Ark Items - This ended up being the easiest item once I received the Modbus document from Sol-Ark. In the latest manual version they dedicate a section to the RS485 connections but leave out some key details unless you ask for them. They are contained in the attachment that I added to the post. In short depending on what version of Sol-Ark you have, 8k, 12k, indoor or outdoor model there are slight variations to the wire connections.
- RPI - Zero W - Out of the box setup
- Modbus Interface - Biggest PIA was trying to troubleshoot the driver issues with the 1st two devices. Literally spent more time on this setup step then the actual connection to the Sol-Ark.
- WaveShare RS485 CAN HAT for Raspberry Pi https://www.amazon.com/gp/product/B07VMB1ZKH/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
- Was unable to get it to work, I believe it is a driver issue
- Industrial USB to RS485 Converter Adapter Original FT232RL https://www.amazon.com/gp/product/B081MB6PN2/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
- Did not work on the RPI but did work on my Mac
- JBtek USB to RS485 Converter Adapter ch340T https://www.amazon.com/gp/product/B00NKAJGZM/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
- Work with RPI and what I am using today
- Node-Red - Running on the RPI Zero W
- Established JSON flows are already available for download from the powerview threads listed above. make note they have to be updated for some items that relate to single phase.
- InfluxDB - Running on a RPI 4
- Standard setup
- Grafana - Running on a RPI 4
- Establish JSON dashboards are available for download from the powerview threads.
As of now I have been collecting data for the past couple of days and still in the process of building a dashboard but when it gets to a semi sold form I'll share it with the group. If you are looking for an example or a template you are better off grabbing one of the ones already posted and building from there (what I did).
NOTE - Some of the flows / setups that you may come across allow for the changing of inverter settings, modbus write actions. The Sol-Ark document excludes those settings but the SunSynk has them. For my own personal setup I only use the read only modbus options at this time to avoid any mistakes until I get a good handle on what is available and what I want to do eventually.
Good luck!
I'm using the JBlance mppt python package. https://github.com/jblance/mpp-solar I had to tweak a few things and I only get updates every 3 mins because of the bluetooth lag.What Software did you use on the PI to talk to the JKBMS via BT?
I have Solar Assistant talking to my 2 Sol-Arks.
