Firetodd
I can’t seem to connect to the MPPlv6548 through the WatchPower app. Does anyone have any tips?
It’s crazy, here is my solar input right now, but I have a 3s2p panel setup that should be 18amps, at about 122 volts at peak. I know amps will be less if not need by battery and voltage will be less, that seems way off.
Sorry pictures just posted above. Cell coverage kinda sucks.Image?
You can disable the Equalization. And yes, it should be disabled.LiFePO4 shouldn't have an equalization phase. If you can disable it, do so. Otherwise, I think I've read that making the voltage for the equalization phase the same as the float works.
