jfm30204
- Jan 18, 2022
- 6
I just bought a cheap 100w portable solar panel and was, naturally, suspicious of the true output. the size seemed okay, based upon that for other "more legitimate" panels on Amazon. So I discharged my Jackery Explorer 300 a bit and hooked it up to the panel. With noon-day sun at the optimal angle to the panel, the max output was 52 watts. Then I hooked it up to the same brand power station that was almost completely discharged, and it also showed 52 watts. Is it possible that the controller in these units are restricting the input to 52 watts, or is it more likely that the panel is not up to snuff?
