Do you happen to know the size of the wires inside your batteries? From the batteries to the BMS, then to the battery post?
One of the problems with prepackaged batteries I've found is that it's imposible to know the size of the wires they used inside the sealed units (unless you want to void the warranty by cracking them open). Don't forget that this appies to the bus bars connecting the batteries as well.
Here is a pic or wire AWG and length to how much voltage drop you can expect at a certain amp draw:
As the chart shows, in essence the longer the wire the more voltage drop you get at higher currents.
1 AWG wire recommended by SRNE should be fine for most people, since most of us don't run the inverter at max power all the time.
Let's say as an example:
load: 52V at 150A, 5 foot , 1 AWG wire => 7,800 watts at 50.44 volts at the inverter and about 154.64 amps coming out of the battery to make up the difference in voltage drop (approximately) 3% drop
load: 52V at 150A, 30 foot , 1 AWG wire => 7,800 watts at 46.8 volts at the inverterand about 166.67 amps coming out of the battery to make up the difference in voltage drop (approximately) 10 % drop
***congratulations, your wire has now also become an 87 watt heater as well, approximately, lol***
If you draw more then 150 amps on above wire, then the voltage drop will increase slightly and the wire will get warmer (how much warmer will depend on the current), but will still work.
Now you are just loosing more power to heat instead of going into your load.
In my opinion, the shorter and bigger AWG the better when dealing with batteries.
