timselectric
- Feb 5, 2022
- 18,611
All of the cool kids were. Back in the 60s. lolWhat have you been doing , pooring oil down the drain and clubbing baby seals ?
Only if you controlled all the pv production. You are only worth the value of the last turbine to spin up (or cost to spin down - it costs to spin down base load generation to spin it back up later in the day. Or to wheel it to farther areas that can use the power).Utility wants to say the power we produce is only worth the market price of the last kWh, which may be negative (on occasion they have paid other states to take a little bit). But if we were to turn off PV production, utility would have to buy a massive amount of power from peaker plants, and would have to transmit it. That price per kWh should be used. Avoided cost.
Originally, net billing occurred at the end of each 1-year period. The grid served as a free battery.
Time of use metering was optional, so with higher rates Noon to 6:00 PM (when demand was highest) I might get credit of $0.32/kWh, and for night time loads I was charged $0.08/kWh. My panels were oriented for 2:00 PM sun, and I estimated I got 1.5 kWh back for every 1.0 kWh exported. That was 20 years ago.
Today, there is considerably more PV product during middle of the day, making a large dent in California's consumption.
The grid's service of carrying power I produce to others during the day has value; they could be compensated.
I think that due to PV production, the utility has gotten away with not having to upgrade infrastructure as much to support growth of consumption. That is value we bring them, so I don't think our credit for export should just be wholesale generation, should include their savings in long distance transmission.
Utility tried to get PUC to approve charging us net money (about $0.03/kwh) for all power we produce and deliver to them. And $0.08/kWh for all power we produce and use immediately. The PUC instead approved $0.00/kWh for export and $0.05 for power we make and use. But that wasn't implemented; a different credit of a couple cents per kWh export is now in effect for new PV adopters.
Has anything been decided about new rules / fees going into effect in 2025?So they are trying other approaches to go in effect in 2025: Flat monthly charge for infrastructure, smaller charge per kWh.
Will these new rules / charges going into effect in 2025 impact existing NEM customers or only new installs?
I’m interested in any links you have to new changes expected to come into effect by 2025…
For an example of this, in my last months electrical bill from AES I was charged 12.38 for my supply total and then they added 14.66 for delivery.Only if you controlled all the pv production. You are only worth the value of the last turbine to spin up (or cost to spin down - it costs to spin down base load generation to spin it back up later in the day. Or to wheel it to farther areas that can use the power).
Note: in theory, you should be charged the distribution cost of the Energy exported. Think of it as the cost the utility incurs to take the power from you. If you want to setup the transmission lines to sell the power directly to a nearby factory, go ahead. That is why your power is only worth the generation cost, and not the full amount you are charged for each kWh you consume.
Either store the excess yourself, or the utility has to incur the cost of storing all the electricity above its base load generation for use later in the day. Someone has to pay for the time shifting.
Has anybody considered the wear and tear on their EV from the power company using the power and then you recharging adding to the battery cycle count basically, you’re paying for the storage system maintenance on the system and all the wear and tear shortening the life of your EVGrid-tied is for suckers. Or grid connected in any way, for that matter. Get out while you can.
Otherwise, you will be left carrying the grid alone.
Disclaimer: this is just my opinion.
I hadn’t realized the ruling is expected by next year and could impact minimum monthly charges as early as 2025: https://sfstandard.com/business/pge-rates-could-drastically-change-based-on-your-income/Just seeing articles. $20/month for poor people, up to $93/month for high income people in PG&E district, $145/month for high income in Southern California.
To be revenue neutral, reduced per kWh rate but no word on what that is.
Rate changes have generally applied to everybody regardless of what net metering. Multiple rate plans, sometimes obsoleted and we're bumped onto another.
California law requires new homes to have PV (buyer pays for that), credits for export are below retail, so home buyers are required to give PG&E power for a loss. This new plan increases their monthly fee and further reduces retail rates, but may not affect NEM 3.0 credits which I think are related to wholesale power cost.
Not a loss if the marginal cost of production is $0.00. Cost of hardware is amortized against kWh consumed.so home buyers are required to give PG&E power for a loss.
I buy a battery for backup if the grid goes down. If I can make a few bucks being a virtual power plant, or TOU shifting, it is icing on the cakeIf you have net metering, don't have to buy a battery for storage, it is a fantastic deal.
We’ll see how it all plays out. I’ll be surprised if we see major changes approved by next year - they are going to need at least 18 months to digest the changes they have just approved for NEM 3.0."The flat rate pricing model"
Most of these articles make no mention of a per kWh rate which will also be charged.
Probably so majority of the public will think, "Just $15 or $30 flat rate per month; that's less than I pay now!" and will support it.
Youre also paying now with more expensive dollars so the inflation thing is kind of a washThe problem I have with waiting until your current agreement is about up is legislation and regulations change over time. Sometimes the early bird not only gets the worm but is grandfathered in.
Utilities are pushing for more regulation on solar that is not grid tie. They see a dwindling customer base if widespread adoption takes place. Of course, politicians will say they are for the "poor people" and only the rich can afford solar, so the cost of production and distribution needs to be spread across a greater number of customers being fleeced.
Another aspect is inflation and how that will affect the cost to produce your own power. Paying now and locking in the price of production can be quite beneficial to the return of the system. An example is $40K with inflation at 5% compounded yearly. The system would cost an additional $8.6K in just 4 years time. That is $2,150 per year. For the 12Kwh/per year you currently use, that would be $0.179/Kwh for inflation on the cost of a system.
Is it possible the price for a system might come down with increased competition and widespread adoption? It is possible but considering the far reaching effects of inflation on the costs of production, it would take a big increase in efficiency for production to keep those costs down.
