It's never worked for me with powerview, so I'm not expecting it to work with Mysolark.The power local power company is changing a nearby pole, and cut power to our property. MySolark did NOT send a power outage notification. All notification settings in my phone are correct. I can see there is no grid power, but unlike PVPro, I did not get a notification. Another bug/glitch?
Does even SA do notifications properly?It's never worked for me with powerview, so I'm not expecting it to work with Mysolark.
Solar Assistant is adding notification shortly, so once again, SA to the rescue.
They haven't implemented it yet.Does even SA do notifications properly?
Been delayed again, I'm seeing September now for that feature.Does even SA do notifications properly?
Yeah, I think the first time it was supposed to happen was end of last year. I'm getting software deja vu.Been delayed again, I'm seeing September now for that feature.
I implemented Home Assistant and set up notifications through that.Does even SA do notifications properly?
Yeah, I never had one issue with Powerview.I always got notifications through Powerview. "name of plant" is disconnected from grid, then, "name of plant" is reconnected to grid.
To my knowledge it will be a complete transfer of your historical data. We chose to migrate the actual inverters and migrate the data later.Does that data transfer include the days during the transfer?
Also, the data for E-Today on the plant screen seems to be reporting consumption, not PV production. Is this a known issue and is it being worked on? Inverter numbers for the day appear to be correct, month is still off, but nowhere near as off as the month total on the plant screen.
All of a sudden, without me doing a single thing (decided from the beginning that I was going to wait a month before trying to change any settings or contacting support), the data in the new app and https://solarkcloud.com is much more complete and looks a lot better, though it is still not as good as it was with PV Pro (i.e., not yet every 5 minutes, but getting closer). The data has much more frequent data points starting yesterday afternoon. This is reassuring, for now I'll just wait some more.
Opened both up, there's absolutely no difference between the two for me.I was not aware of this address - https://solarkcloud.com
I have been using this one - https://www.mysolark.com
The cloud site is actually showing data for my power graph and the energy generation graph at 5 to 10 minute intervals.
Where as the other site only shows the energy generation graph and is way behind in it's updates many times when I have viewed it.
Edit: Ok, I spoke too soon. As I typed this the cloud site power graph now has no data. WTH is going on?
Normally PView would send a power outage alert even if the power glitched for a fraction of a second.I wonder what the timeframe is for reporting. Does power have to be out a certain length of time?
I lost power 6X last night from a lightning, but each was just a flash, inverter took over each time for just a minute, the time it takes to cut back in.
If you keep watching this thing you are going to be like a Dog chasing it's tail.I was not aware of this address - https://solarkcloud.com
Sure would be nice if someone notified me about that?If you keep watching this thing you are going to be like a Dog chasing it's tale.
They are literally taking it offline at points to do work and then putting ti online to check stuff.
This system will probably be unstable for few more weeks.
They sent out several email notifications over the last few weeks.Sure would be nice if someone notified me about that?
Then I would have known this.
Sol-Ark has my email
What is so difficult about updating customers with info?
BTW, I am only checking my battery levels and solar input like I did on PV View
Does anyone know what the difference is between these 2?? From what I can see, they appear to be exactly identical...I was not aware of this address - https://solarkcloud.com
I got nothing.They sent out several email notifications over the last few weeks.
There doesn't appear to be a difference, but I recommend continuing to use the mysolark.com domain just incase.Does anyone know what the difference is between these 2?? From what I can see, they appear to be exactly identical...
Maybe @Carlos_Sol-Ark can you tell me?
I have just been using mysolark.com all along.
