So after last Winters debacle down here when the power was out for almost 3 days and the temp got down to 25 degrees about 10 miles from Mexico, I am looking into using the batteries in our golf cart as the battery pack for an inverter to power the refrigerator. The house fridge is 6.5a, but just got a mini fridge rated at 1.1a which might be a better option.
The cart is 48vdc (6 8vdc brand new deep cycle batteries) The batteries are rated at 150 (20hr) 120 (5hr). Thinking of purchasing a decent not too expensive inverter 2000-3000w.
First question: What input voltage inverter....48 or 24 vdc? I could reconnect the batteries to obtain 24 vdc, but would this get me more or less run time? I know the wiring would need to be larger to the inverter with 24vdc. I don't think you can run a 12vdc inverter from 16vdc battery pack and the wiring is again even larger?
Second question: considering some type of portable solar charging system. To charge a 48vdc battery pack I think I would need something like 5 or 6 panels. That's too many to set up temporarily and nowhere to store them. I think the 24vdc system would only need 2-3 panels maybe? Also the charge controller might be cheaper?
i know these subjects must have been discussed here before but I could not find what I was looking for. Thank you for taking the time to read this and possibly supplying more info.
