Horsefly
Solar Wizard
Two potential problems with the cheap Amazon power supplies that I've either heard about here on the forum or experienced myself:
- Some of the power supplies tend to go up in voltage as the current gets low. I've never seen this, but a couple of posters were certain that they had not touched the voltage dial, but found the cells ended the top balance at a higher voltage. Obviously this can be disastrous.
- I have had one power supply that turned into a load once it was turned off. I had been charging or top balancing (don't remember which) and then turned the supply off and disconnected it. A few minutes later I started to hook it back up (while it was still off) and I got a pretty big spark. Thinking it maybe was an inverter-like pre-charge thing, I disconnected it and immediately reconnected it. Again, a big spark. I then used a clamp meter and confirmed that there was around 4A flowing INTO the turned off power supply from the cells. Not good.
