It will work. Just don't plug back the AC plug to the wall to charge the UPS' new Lifepo4 battery. That default charge profile on the UPS is meant for the SLA/LA batteries. Use a SCC or differ DC charger instead.i have a tripp-lite UPS,batts are dead.thinking about putting lifepo4 on them with a BMS.
what do you all think about that idea?
Kinda defeats the purpose of a UPS. Intent is to run on wall power then automatically switch to battery in grid down.It will work. Just don't plug back the AC plug to the wall to charge the UPS' new Lifepo4 battery.
why not just use the BMS as the charge controller?
other wise,i do have 4 AGM 100amh Batts just sitting.maybe use those instead.
so good then,i got all the time in the world.That will take forever to fully charge the 100ah AGM batteries if you even draw them down. It will work as their in the SLA/LA/AGM battery family for UPS.
Edit: will a blocking diode prevent the UPS from charging the battery? Otherwise will be in eternal float.
I think my UPS has a port on the back for an external battery. That might be the way to go.
A blocking diode would allow current to flow from the battery and power the UPS section, however block charging current to flow into the batteries.Not quite sure what you are getting at. A blocking diode allows current to flow in only one direction...so
If its an Anderson-style connector yes. Some have a small port that is only used as a battery disconnect.I think my UPS has a port on the back for an external battery. That might be the way to go.
Its not necessarily a pure heat equation (though it might be) . Some of these devices were designed with only a certain lifetime in mind. You probably could get a few good years out of them (I've rarely seen the electronics fail)Duh...don't know where my mind was. Thanks. I don't know how much of a voltage drop there would be? Of course that needs to be taken into consideration.
As far as running a UPS for a long time, wouldn't adding a fan to keep the UPS cool solve the problem? Pretty sure I saw a youtube video of someone who did.
