1jesusmoreno
- May 26, 2020
- 1
I am trying to make a wind generator with a treadmill motor, and I have been reading about the equipment that I should use such as charge controllers, inverters, batteries, but there is a lot of information on the internet and tons of different equipment and I am confused about what I should use. What I want to do in the future is to use this system for a submersible water pump.
pump motor specs:
Franklin Electric 4" Submersible Motor Specifications
pump motor specs:
- BODY CONSTRUCTION: 304 Stainless Steel
- HORSEPOWER: 1.0 HP
- VOLTAGE: 1ø, 230V
- RPM: 3450
- SERVICE FACTOR: 1.4
- DOWNWARD THRUST (lbs): 650 lbs
- MAX AMBIENT TEMPERATURE: 86°F/30°C
- DUTY RATING: Continuous
- FULL LOAD AMPS: 8.2
- LEAD: 2-Wire, XPLE
