@JoeHam You mean this one: https://diysolarforum.com/threads/i-let-the-smoke-out-of-my-mppt-scc.3988/
I thought you said that was a polarity error?
WHY are you polluting our threads with this nonsense ?test.....70 v into 12 v battery...pull battery wire out put back in.....repeat till it blows
That makes no sense unless you're trying to blow up your battery with a direct connection to the panels or some other higher voltage source. Where is the 70V coming from? Maybe that's the input to your SCC, but the output wouldn't be.test.....70 v into 12 v battery...pull battery wire out put back in.....repeat till it blows
Reverse polarity SCC destruction is not what we were talking about. We are talking about leaving SCC connected to array, but disconnected to the battery.My thread on the one I destroyed 2 weeks ago included pictures!
That will only happen with Electrodacus's earlier SBMS modules that have PV and LOAD connections at the SBMS (e.g. SBMS40, 120, 100, etc). Not a problem with latest SBMS0 since it sits outside the Load and Charging circuit. Much better design. Also results in the fact that no heat sinks are required since the shunts are now external to the SCC too.
So I took every EPEver/Victron/PWM/Renogy solar charge controller, and tried to fry it by connecting it only to solar panels, and not to a battery... guess which one survived?
EVERY SINGLE ONE! I couldn't destroy any of them, and I left them connected to a high voltage array (80 volts) for 4+ hours each.
I connected each one to a lifepo4 bank after the test, and they functioned perfectly. Tested output with a watt meter before and after as well, no change.
I read in the manuals that you must NEVER connect an SCC to an array without connecting it to a battery first, because the potential that it can fry. I know that having improper gauge wires on an SCC can cause overheating around the terminals (dedicated voltage sensing leads would probably fix this problem, but many SCC use the charging lines as voltage sensing, which makes it wise to over gauge them most times. The voltage drop of a long run of hot wire can be horrible). But to actually connect an array to an SCC, and not to a battery, in my experiments, no issue.
I am thinking that the feedback signal in the converter circuit needs a reference voltage at the output to work. Then it can track the power point between the panels resistance and internal resistance of the battery, then push current to the max. If you only have the input powered up but no current is flowing, what would it stress? The panel would be in an open circuit voltage, and possibly use some power to charge up caps on that side of the circuit, but thats about it. Should be fine to leave connected.
Am I wrong? I know some MPPT's circuit designs are pretty complex, but they are still a simple converter circuit with inductor and capacitor and basic logic system to modulate it. I know some current limited converters can handle amp sources at input/output, and others can't. but because the solar panel is open circuit in this instance, and the output is also voltage sensing of the battery, I don't think any damage can occur.
What do you guys think? How can I destroy one?
On page 6 it tells you to connect in exactly the sequence pictured, which is battery first.
Section 3.4 Cable connection sequence
The system is now ready for use.
- First:connect the cables to the load, but ensure that all loads are switched off.
- Second: connect the battery (this will allow the controller to recognize system voltage).
- Third: connect the solar array (when connected with reverse polarity, the controller will heat up but will not charge the the battery).
How about doubling the max solar panel watts Input to MPPT. Even though solar panels rarely put out rated watts, I wonder what the limits of oversizing solar input beyond ratings will do, and what is are the limits.So I took every EPEver/Victron/PWM/Renogy solar charge controller, and tried to fry it by connecting it only to solar panels, and not to a battery... guess which one survived?
I do not think it is a problem. Think of this if your batteries are full and your SCC is in float mode it is holding back 90% if the PV power and the SCC does not even get warm in float mode. So I'm thinking you could throw 10x the rated capacity with no I'll effect. Not that I would try 10x but 3x seems reasonableHow about doubling the max solar panel watts Input to MPPT. Even though solar panels rarely put out rated watts, I wonder what the limits of oversizing solar input beyond ratings will do, and what is are the limits.
my post got inserted here on page three, but flipping through threads; I was respond to beginning of thread and Will's:I do not think it is a problem. Think of this if your batteries are full and your SCC is in float mode it is holding back 90% if the PV power and the SCC does not even get warm in float mode. So I'm thinking you could throw 10x the rated capacity with no I'll effect. Not that I would try 10x but 3x seems reasonable
Rightmy post got inserted here on page three, but flipping through threads; I was respond to beginning of thread and Will's:
Trying to destory my SCC's: I can't do it! ... How can I destroy one?
(letter got big from copy n paste/ not my intension)
