Hey all,
Summary: Are there any solar generators that run loads from the Inverter all the time even when being charged via AC?
Details:
So I have an issue that I run into at our off-grid cabin. (It's a 1st world problem, I know)
I have my cabin wired to run off a 1200W inverter running through a transfer switch that lets me run a generator when needed. Inside, I have a TV, DVD Player, and XBox 360. The problem arises when the transfer switch switches from Inverter/Generator. The transfer is not fast enough and the electronic devices all shut off. And then I hear the complaining from all the kids
Short of replacing the transfer switch with something much faster and more expensive (which would probably be way overkill for our cabin). I'm thinking I could get a small solar generator (something in the range of 300-400 watt inverter) to act as a UPS between the electronics and the power source. I could also use this solar generator to carry back and forth from home to the cabin and for other uses around home when necessary.
So I would not be using this solely as a UPS, just something that would keep the electronics running for the 1-2 seconds between Inverter/Generator transfer. I was originally looking at the new Bluetti EB3A since they advertise it as a "UPS". However, after contacting them, they said it is a 20ms transfer time. I don't trust this to be fast enough to keep the devices from shutting off.
So my question is: how do other solar generators handle "pass-through" charging? I guess I'm actually looking for a unit that will run from the inverter all the time even when being charged via AC. Any suggestions on a small unit that can do this?
Thanks,
Jeff
Details:
Thanks,
Jeff
