justinm001
- Dec 18, 2022
- 1,534
I had an issue over the weekend where my batteries BMS's were tripping and needed to precharge the 2x5000w Quattro inverters which have massive capacitators. I know the SOK batteries have a precharge setting but it a bit complicated and I need to google it everytime.... I really need to print a label with any instructions and just stick to the batteries. I messed with the batteries but was having an issue keeping them out of SCP even with breaker off and when they did I messed up turning on the precharge option.
So I turned the key on my RV to on and used my 4x400w 24/48 DC to DC chargers and the inverters powered up instantly with no issues. This happened a few times yesterday and each time it worked perfectly.
I know the capacitators use a ton of power for milliseconds to charge which cause the issues with the BMS thinking they're short circuiting. But is it safe to use a DC to DC charger? Should the battery breaker be off or on or does it not matter? The chassis batteries are 4 huge lead acid starter so inrush shouldn't be an issue with those, just unsure how it affects the DC to DC converters. Also Victron only makes max 400w for the 24/48 so even though I have 4 I worry it could be using 1 for that split rush and unsure how much power the capacitators actually pull, or if the DC to DC converters safely limit the power so it doesn't matter.
