MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
I’ve seen a few posts concerning using the load terminals on Charge controllers and see where some try to use them for loads too high causing problems. Some say not to use them at all.
I use this feature only on low power outside led lighting and use the timer function to set on/off power to lights. you can also use it for dusk to dawn power or manual on/off switching too. I use the same led lights we have used on the rear of cement mixer trucks for night work where they take quite a beating in dirty wet conditions also they are quite bright and draw little power. Appx 27 watts.There are many other low power uses for the load function but I would only use them for low power only.
These lights are inexpensive and generally tough and long lasting.
Here is picture of what I’m talking about. (Similar to what I’m using)
![9DC93E95-3BED-45A2-91FA-5A38B7BF0D08.png 9DC93E95-3BED-45A2-91FA-5A38B7BF0D08.png](https://diysolarforum.com/data/attachments/0/886-0c08d8c44b36f7e08be5a24a4dcbd341.jpg)
