Cliffman
- Oct 30, 2019
- 45
I'm more computer illiterate than savy. Plus I have a sizeable DC demand starting with a residential fridge, +. Any chance of getting the software?
I have 6, purchased two different times, all came from Staples trucks. None of them have cycled more than 200 times. The last two less than 50Been thinking about replacing my Lifeline AGM batteries with one of these. I've seen a couple on ebay used, but I'm concerned about the previous usage which seems to be either bus fleets or Staples delivery trucks which see heavy usage for about a year to a year and a half.
I have been getting mine from people in Milwaukee, there are different ones but I think source is the same. They have been buying trucks all over the country though. Last two I bought I took laptop and they let me plug in to look at bms info.Any way to tell whether the battery is coming from a good source and do you happen to know which seller on eBay you went through?
The rating you select depends on your charger and loads you intend to run and are fused for. The battery itself can do 150 amps for discharge and can be charged at 70 amps.Ended up buying an older black Valence U27 from ebay. Fingers crossed it works well for boondocking. Seller supposedly ran the Valence software and said this lot only had 70 cycles (I want to believe). Going to test it out camping this weekend which will replace my dual 12v parallel Lifeline AGMs. Initially, I'll have it in a battery box on the tongue but will eventually move it into the storage compartment under the bed for better temperature regulation and security.
On a side note, I'd like to have this battery be removable as I'm forced to store my trailer in a storage facility. What would be a safe amperage rating for a Anderson connector so the battery is easily removable and able to be brought home to charge and store without having to use tools?
I don't see any issues with that. Guess we'll see if the rest of the collective has to say....Nothing too crazy, I currently have an EP EVER 30amp MPPT controller and one 100w solar panel (not mounted) that I move around while camping. I eventually want to get the MPP Solar 12v unit that Will reviewed a while back but they're out of stock to replace my onboard 12v/120v electronics. Realistically, a 175amp Anderson connector should be sufficient for continuous charging and loads?
What float voltage do you recommend? Also, just an FYI for anyone interested. I use my inverted for my battery protection. I have my low voltage cutoff set pretty high so when and if I go below that the only thing pulling from my batteries is my low voltage DC circuits which are mainly my LED lighting. So if I'm out and about and that happens I'll be able to crank up the gen set and recharge.The main thing I'd add to this conversation is just to point out that Valence U27-12XP batteries are not drop-ins; they have internal monitoring, yes, but no true BMS for HV/LV or hi/lo temperature cutouts... so always keep an eye on them, because they will not shut themselves down before any charge/discharge condition might kill them.
Only the U-Charge RT series batteries are drop-ins. Every other model, as expressly stated by Valence, "requires the Battery Management System", which of course is not available for retail purchase, thus the workarounds that people have developed.
I don't see any issues with the charge rates mentioned above, just keep a really close eye on everything until/unless you have your batteries connected to 3rd-party HV/LV cutouts and (ideally) temperature-sensitive cutouts as well. Otherwise, if that Epever ever decides to throw 16v at your batteries, or any number of other possible conditions, the batteries will be crisped rather quickly because they're not capable of shutting themselves down.
I do concur with the use of a 175A Anderson connector, though - those things are great and on my test bench I have consistently run way more than they're rated for through them without any issue... not that I recommend doing that.
Unfortunately, we do not deal with these batteries (strictly Victron and Battle Born when it comes to batteries) so I can't offer any meaningful advice re float settings for them.What float voltage do you recommend? Also, just an FYI for anyone interested. I use my inverted for my battery protection. I have my low voltage cutoff set pretty high so when and if I go below that the only thing pulling from my batteries is my low voltage DC circuits which are mainly my LED lighting. So if I'm out and about and that happens I'll be able to crank up the gen set and recharge.
did you ever figure this out?This is the issue I've been having, but I haven't plugged in the battery to the computer.
Adamant- Can't wait to see if this works. I ordered 4 of the batteries. I ordered the vectron multiplex 3000 inverter as well so I'm hoping via some means or settings I can protect the batteries.FYI, new product on market, a BMS for the Valence U27-12XP batteries Much less cost that Valence (hard to find) units and can program yourself easily. Tradeoffs, less overall features, but will probably handle 80% of users out there. https://www.thunderstruck-ev.com/valence-battery-bms.html
I ordered one today. Will report back when I get to take it for a drive.
