George Mitchell
- Nov 2, 2020
- 21
The solution I came up with is to use a voltage monitoring relay to control a solenoid that shuts down my inverter when the voltage drops to 12 volts by disconnecting its DC power. I also power the solenoid via the inverter so that a low voltage shutoff is permanent until I manually restart the system by momentarily transferring it to grid power. That way the system is not cycling on and off as the panels try to keep up with the load. I also use an automatic transfer switch so that I can run the inverter into the night and at the moment it shuts down, grid power instantly takes its place and the load is not interrupted. I have using this system for several days now and it has worked flawlessly and requires no smartphone or computer interface to program and function. I have a computer background and for some things I prefer mechanical solutions to automated solutions.
