S SteveDeFacto New Member Joined May 16, 2022 Messages 28 Dec 1, 2023 #1 I have a generator connected to my victron quattro II producing 1300w. When I look in the VRM portal, it show this: Why is it discharging for almost 900w while I'm only using 200w? Shouldn't it be charging my batteries for roughly that much instead?
MisterSandals Participation Medalist Joined Nov 5, 2019 Messages 10,085 Location Silicon Valley Dec 1, 2023 #2 Do you have a Victron BMV? If so can you show how its wired?
S SteveDeFacto New Member Joined May 16, 2022 Messages 28 Dec 1, 2023 #3 MisterSandals said: Do you have a Victron BMV? If so can you show how its wired? Click to expand... No BMV or even BMS, Tesla Battery Module -> Shunt -> Distributor -> Quattro-II. Was handling balancing with my iCharger before the Quattro-II. Now I'm working on setting up a Orion 2 BMS instead but it isn't connected yet.
Adam De Lay Solar Wizard Joined Aug 3, 2021 Messages 2,055 Location MI Dec 2, 2023 #5 Is the shunt wired backwards? That would show charging as a negative value.
S SteveDeFacto New Member Joined May 16, 2022 Messages 28 Dec 2, 2023 #6 Adam De Lay said: Is the shunt wired backwards? That would show charging as a negative value. Click to expand... Maybe? What's the other direction?
4 42OhmsPA What's in a title? Joined Feb 17, 2022 Messages 5,665 Location Pennsylvania Dec 2, 2023 #7 SteveDeFacto said: Maybe? What's the other direction? Click to expand... The opposite of what it is now.
S SteveDeFacto New Member Joined May 16, 2022 Messages 28 Dec 2, 2023 #8 Adam De Lay said: Is the shunt wired backwards? That would show charging as a negative value. Click to expand... Yep, that was the problem! Ghee do I feel smart... I watched some YouTube video about installing it and the guy said, "It has to be installed from right to left" so I clearly misunderstood his meaning.
Adam De Lay Solar Wizard Joined Aug 3, 2021 Messages 2,055 Location MI Dec 2, 2023 #9 SteveDeFacto said: Yep, that was the problem! Ghee do I feel smart... I watched some YouTube video about installing it and the guy said, "It has to be installed from right to left" so I clearly misunderstood his meaning. Click to expand... Awesome! Glad it’s working. Don’t ask me how that came to my mind…?
